The relay coil will be powered when the actuator is moving the return valve to Pool Position.
Just measure if the voltage is Black and Red or Black and White when the Pool Return is open.
You can power the Relay Line In from the Pool Pump Relay Load out terminals to make sure that the Pump is on when the acid dosing is on.
www.troublefreepool.com
Valve Actuators - Further Reading
