- Jun 24, 2024
- 11
- Plaster
- Pentair Intellichlor IC-40
Hey all! I have a 15K gallon, Marcite pool. SWCG.
Im using a K2006 test kit and my readings this morning were:
pH7.4
FC 10
Comb Chl 0
CYA 70
Cal Hardness 400
TA 110
I'm changing the settings on the SWCG to get it dialed in, so I'll get the FC down to about 5.
My question/concern is with the TA. It was a little higher, about 120, and I added Muriatic acid per pool math to bring the pH down to 7.2. The TA dropped 10, but my pH isnt coming up very quickly, even with 2 fountains aerating. I want to get the TA down to the low end of ideal, 60-65, because I want to add Borax. The article/forum post I read here says start with TA on the low end. I read that Borax will raise the pH (which is why you add so much Muriatic acid to combat the rise in pH). I guess my question is: Can I add Borax to raise the pH and add Muriatic acid to lower the TA until I get the TA down to 60ish, or will the Borax raise the TA as well as the pH? I read on here that the only way to raise pH is through aeration, which is what pool math recommends. But sodium carbonate raises pH also. Is it just that aeration raises pH without impacting any other levels?
pH7.4
FC 10
Comb Chl 0
CYA 70
Cal Hardness 400
TA 110
