In advance, excuse my lack of proper terminology but hoping you can help. Here's what's going on. This morning I put the pool in service mode to empty the filter--the little basket that's connected to all the pool equipment:
I've done this before so not a new process, although I will add that every time I do it the pump is finicky for a while afterwards. Anyway, took care of it, put everything back together and turned the pump back on auto, out of service mode. I'll add that the skimmer baskets in the pool are also totally empty.
It's probably been an hour that I completed all this. Well, ever since I've done this, the pump has been completely unresponsive to the Pentair app on my phone. I've tried to adjust the speed to no avail. For example, I'll set it to 1000 and it will show as idle. I'll try to change it to 3450 and it will do nothing. It's like the pump is doing its own thing. And then I heard the pump kick in, so I assumed it was just a delay (sounded like it sounds when I have it at 3450), but there was nothing coming out of the jets in the pool--no pressure.
Can anyone help troubleshoot? TIA.
