A few years ago my pool heater stayed on for days without my knowledge and fried my multicolored light. Everything else worked fine. I just replaced the light and now the VSF Pentair pump only works in manual mode with the RS485 cable removed. I had the cable replaced and the same problem exists. The easytouch panel and intelliflow app cannot control the pump remotely. A Pentair technician on the phone remotely rebuilt the settings for the easytouch / intelliflow parameters. When the RS485 cable is inserted, the display shows ‘display not active’ normal, but the pump won’t respond to remote commands from the ET or screen logic app or remote control. All other ET functions are fine, lights, spa, heater…
A Pentair recommended delaer/technician replaced the cable and suggests the pump drive unit needs replacing. My question is this. How could that be if the pump works in manual mode just fine? How could replacing the drive unit fix this remote fault? What is the likely fault?
I’m new to this forum and this is my first pool, five years in now. Thank you for your help.
