- Sep 7, 2009
- 396
- Fiberglass
- Pentair Intellichlor IC-30
A little backstory.....
I have had the iChlor30 for a couple of seasons and until recently a Pentair Whisperflo 2-speed pump. I typically ran the pump on low 24 hours a day with a low setting on the iChlor and have had great water and no issues. Both pump and iChlor were wired together so when I turned the pump off, the iChlor went off as well.
Fast forward to last week when I replaced the Whisperflo with the VSF. Wiring remains the same but now I am running a program with the VSF and when it turns off the iChlor remains on but shortly turns off since no flow is detected. All of that makes sense. However, is it normal to rely on the flow switch of the iChlot to always work reliably and prevent the iChlor from making chlorine when the pump is off.
Seems ot me that it is a bit risky. Plus I do not like the red lights flashing. Should I have wired this differently?
