Pentair vsf 1.5 hp program issue
mdhwoods
0
144
Sarasota Florida
Just installed the above pump and I’m using the app to set up programs. I have four programs set but for some reason instead of showing the proper next program that will run. It shows the improper program that will run. All my times are set correctly and any help is appreciated. Program 4 should run next, but you can see. That’s not the one that it says. If I delete program 3 that it says we’ll run next it then shows program 4 will run as the next program. But if I re-create program 3, it goes back to the next program to run.
