Hi All, I have looked through previous forum messages and can't seem to figure this one out, any help appreciated.
Pump seems to turn on but intermittently turns off... sometimes after 5 minutes, sometimes after 30 minutes. Sometimes it gives error code 0017 but most of the time I see error code 001A.
I cleaned out basket, stuck in a screw to loosen anything and rotate impeller, attempted to stick a hex screw in the back. No change.
I opened my breaker box and tested the breaker. Reading 250 L1 to L2. Tested each connector and saw 120 V connector to ground.
Any thoughts?
Any thoughts?
