Originally I noticed pump not running, Suntouch displayed Air Error. I recalibrated but correction lasted only until the next day. I switched out air temp sensor and got pool running again with no errors on display albeit with incorrect temp. Air temp fluctuates about 5 - 20 degrees off usually too high. Recalibrated but change held only until next day. Not a huge issue as I am not using solar heating at the moment conversely the freeze protection doesnt work either.
Im thinking at this point I will need to replace circuit board, after 10 years maybe its time? thoughts?
