Pentair sheer descent wall - potential leak
Jun 4, 2024
7
Texas
We built a pool earlier this summer. I have a 5 foot sheer descent water fall that works as it should, however; I have noticed there is an area on the external back wall that looks like it is wetter than the rest. The first thing I noticed before inspecting the back of the water wall, was the actual lip line of the sheer descent is always wet even after not using it for over a month. Is that normal?
My builder is coming to inspect this issue, but wanted to ask if this looks like a leak in the wall (lower left area -picture attached) and how do you test for this type of leak?
TIA
Attachments​
You said the moisture area remains even if you have not run the water feature. What about when you run it for say a full day?
