Hello,
I have a salt system and am using the Pentair ScreenLogic interface. The pool and spa water temperatures showing in the app are significantly different than the actual water temperature. Example: Pentair Screenlogic reads that the water temp is 99degrees, but the in pool thermometer reads that the water is only 72 degrees (and it definitely feels like 72 not 98!). The significant difference is causing trouble when I try to heat the spa - because it thinks it is already 'at temp' and so it is now taking hours to heat it rather than the using 20-30min!
Any ideas of what would be causing this and how to fix it? The pool & system is only 2 years old.
Thank you so much!
Anna
Thank you so much!
Anna
