Ok. This weekend I replaced my old, cracked FNS Plus 60 with a new Quad DE 80. Spent all day doing what I'm sure would have taken a pro 1 hour.
Of course a lot of that was deciding exactly how to do my plumbing. Finally got everything running. The good news is I had no leaks.
Bad news is the next day I had to clean out the pump strainer basket after vacuuming the pool. In opening the air relief valve, I noticed a remarkable decrease in the air flow from normal, and when water started flowing, it was noticeably weak. Curious, I tried it again a little while later. No air, a bare trickle of water.
So, I turned the pump off and unscrewed the valve from the tank. Cellulose fiber (which I use in place of DE) had completely plugged the valve opening up. Between the inner air screen and the opening was also completely clogged. This is clearly not normal, and a problem that I never had previously. I have not checked it again since I cleaned it out, so we'll see if the problem was repeated.
Any ideas on why this happened? I only put just under 6 scoops of the fiber in, which is less that Jack's Magic Fiber suggests (6.67 scoops - 1 scoop per 12 sq. ft of filter). Did I get something put together wrong inside the filter? I know the plumbing is correct (top is the inlet FROM the pool, and bottom outlet TO the pool).
The only plumbing problem I have (I think) is that I need a check valve between the pump and filter. I did not have one before and never had a problem. But when I unscrewed the air release valve, I did get a bit of fiber coming back through the drains. I didn't have a check valve there before, but with the backwash valve I usually had it in backwash position whenever I opened the valve with the pump off. Now I have no backwash valve (still might add one). The pad is a step or two below the water line. The drains plumb to the skimmer not separately. I didn't notice any fiber in the skimmer, only the drains, but then again I didn't actively look there.
Any thoughts on the plugged up air valve would be appreciated - or on anything else I mentioned.
Thank you.
Thank you.
