Pentair PSL4 time is off - how can I reset the clock remotely?
Oh, and I read something talking about membrane switches... where are those? The outdoor panel switches kindof look like a membrane keypad but if you pull the board you'll see they're the standard run-of-the mill 4-pin tactile buttons. The membrane on the outdoor board is only to cover and label the button actuators molded into the bezel
Reactions: GDN
Hi Tom:
Thanks... my SL adapter in the house is connected to a UPS / Digital Loggers Smart PowerBar, so I can reset it remotely. As I found out this past weekend, resetting the unit inside forced a re-sync with the PSL-4 outside.
Cheers,
Ray.
Hi Tom:
Sorry, just saw your post about the switches... so if it's a standard switch, that should make the job of connecting a SONOFF relay across the switch even easier.... another thing to throw into my bag (soldering iron) when we're allowed to travel again!
Cheers,
Ray.
for sure Ray, wiring something to the reset button would be a snap! it's S18, on the right side in the middle of all those caps...
