Moved from here.
Hey just got a Mobile Touch II unit that was used and the battery is toast. Opened it up and there are four Lithium Ion packet cells. Two in series and then a pair in parallel for 7.4v ~1600mAh capacity. No way I'm paying $150+ for a replacement.
Pentair made it tough with the 50mm x 70mm x ~8mm space. Probably going to grab four cells from here:
I will post if I find a pre-made one that fits.
BatterySpace.com/AA Portable Power Corp. Tel: 510-525-2328
3.7v 150mAh - 10000mAh at 1C Discharge Rate
www.batteryspace.com
