Pentair MiniMax 400 not starting
Aug 12, 2016
68
Murrieta,CA
Hello All,
We have a 2005 Pentair MiniMax 400 that doesn't want to fire up when turning on heat, either insde the controller, or outside in service mode.
The LEDs AUX and PRESS are NOT on, and oddly reading the indoor panel, the spa temp says 112 deg. (which is clearly not the case).
Any ideas? Is it the pressure switch, thermostat, temp sensor?
PLease help.
Thank you,
Thomas
Hello All,
PLease help.
Thank you,
Thomas
If the indoor panel reads 112, the automation will not allow the heater to fire. That is the automation's temperature sensor reading a wrong temperature. It is in either the pipe between the pump and filter or the pipe after the filter.
