I've tried a few things and dug around on this forum with no luck...so creating my own post.
I have an old (12yrs) Pentair MasterTemp 400. I turned it on this spring and the unit turns on and fires up but flashes the Service System before the blower kicks on and starts heating...then the Heating led turns off and the Service System turns on.
I checked the back of the Control board and the PS led was turning on and off every so often. The unit still works through all of this but then after maybe 3-4 minute the unit shuts off.
So I checked the flow and everything and all switches are normal. Backwashed and made sure all baskets were empty.
I went and got a new PS and installed and that did nothing. Same results. So using wire, I jumped the PS and it is still happening.
I checked all the wires and there are zero evidence of rodents/loose wires.
So I thought maybe a bad control board...so I replaced that. Still having the same issue.
Is there anything else that can be triggering the PS error other than the PS switch?
Thank you for any help!!
