My Pentair master temp 400 heater had the error for the stack flue sensor, which I replaced(second time in just over 1 year). When investigating the issue(open panels on the heater) I had also pressed the buttons on the heater control panel to try to get it to show more information like the exhaust temp. My suspicion is in doing so I have overridden the Easy touch/screen logic automation and my heater won’t turn on. When I ask for the heater to run via the automation, in pool or spa mode I see the control panel on the heater light up for about 10 seconds, shuts off and the heater never turns on or fires up. The heater was at least turning on just days ago when I discovered the stack flue sensor error.
Any thoughts? My flow is good to the heater, salt water pool around 12-15k gallons with the water chemistry balanced.
