Pentair IntelliFlo VSF Home Assistant integration
dantoraason
10
peoria, AZ, USA
I have the exact same question as this post from over a year ago:
Pentair Intelliflo 3 VSF Wifi pump WITHOUT Intellitouch or Screenlogic - Homeassistant integration?
In a nutshell, I have a Pentair IntelliFlo VSF pump (actually 2 of them) that I can control with the Pentair Home App via a WiFi connection to the internet. And I want to be able to control it from Home Assistant. Surely with the popularity of this pump and the fact that Pentair uses some sort of API (even if not publicly documented) someone has to have figured out a way to do this without additional hardware.
Any tips or suggestions are appreciated.
Here is a good place to start:
Thank you for the suggestion! I looked at that and even tried it but it requires a Pentair ScreenLogic Gateway and I am trying to avoid buying extra hardware for what seems like can be a solution using the existing Pentair API. Even so, I may take a look at the ScreenLogic gateway to see if it is reasonably priced.
I looked at the Gateway and the best price I can find is $350 US. And the functionality it provides is advertised as WiFi access through an iPad, iPhone or iPod touch through their mobile. But this is a capability I already have through the Pentair Home mobile app. Hence the original question.
There are other solutions on Home Assistant. You just have to search for them and read through them:
I dont know anyone that has done a software only interface to the Pentair pumps. My guess is that is something they are not readily willing to publish. Currently the standard for control is through an RS-485 interface. There are lots of ways you can integrate HA with a controller that will talk 485 to your pump.
This is the one most of us (including me) around here use:
Thanks - this is very helpful! I was looking at the
Elfin EW11 RS485‐WiFi adapter​
and the setup instructions. This might work for but I was wondering if it can be done without the Intellitouch controller- in other words, connected directly to the pumps. I don’t have or need any of the Intellitouch features as long as I can connect through Home Assistant. And I guess I will need 2 (at $27 US each on Amazon) - one for each of my pumps - unless they can be chained somehow. (I’m not at all familiar with RS-485 and what it can and a cannot do.) I’ll poke around some more and see what I can figure out. Just wondered if someone has this working directly before I spend money to try it out. Thanks again!
Thanks - this may lead me in the right direction! I’m getting pretty decent at using ESPHome and probably connecting a ESP8266 D1 Mini to a RS-485 to TTL board may do the trick. As I’m learning about RS-485 I’m thinking I can use a single RS-485 board to connect to both of my pumps and see them on the ESP8266 - but even if not, they are really inexpensive, I would just need to have 2 D1 Minis - one for each pump. Thanks!
There is a simple integration to HA through the cloud (GitHub - SPD13/pentair_cloud: Homeassistant Pentair cloud custom integration). This could be developed a little more until someone gets a local integration working. I would guess it is doable by sniffing the internet traffic to the router but doubt Pentair will make it easy. I'm going to start with cloud integration until there is a better solution in place.
I was successful by using a IntelliComm II Interface Adapter, an AEOTEC Smart Switch 7 and two 24v ac/dc adapters. One of them powers the IntelliComm II Interface Adapter all the time. The other 24v ac/dc adapter powers the relay.
If your pump has the IntelliFlo3 VSF optional universal relay board kit installed you can already control it with relays. It can control up to 4 different speeds or flos (or off) via 4 different relays. This is a good controller for it: Amazon.com. I used it with my old VGreen Century pump which had a similar feature. This card install right in the pump and receives power from the pump. you just need to run a 5 wire cable to the controller.
Thank you! All ideas are helpful!
This did it for me! It's a no-hardware solution which is what I was hoping for. It depends on the cloud - but so does the Pentair Home app, so if I can get close to the functionality from Home Assistant, I'm happy. The configuration is weird as it makes each pump preset a "light switch" that is on when that preset is active. I was able to define a set of HA buttons for each of my presets to make a "radio button"-type UI that lets me select any of my presets and shows me which one is currently active - I can even turn that one off to make the pump go off.
