I have a Pentair Intelliflo VSF 3HP pump that trips my GFCI breaker upon turning on. It's controlled by Pentair's Intellicenter. I had an Eaton GFCI and upgraded to a Siemens per suggestions on this forum but the breaker continues to trip. I'm getting around 230-240(I can't remember the exact readings right now) when checking L1 and L2. My Drive screen is getting power and is lit up (although the screen is blank). How can I determine if the Motor is bad, if the drive is bad, or if there's some other wiring issue? Thanks in advance for any and all advice.
