Pentair Intelliflo 3hp VS pump issue with Iaqualink-Jandy
Dashelter
2
Florida
We have a 10,000 gallons pool with a small spa. We have a salt system connected to our pool automation as well.
We have a pentair Intelliflo 3hp VS pump and a pool automation from jandy iaqualink.
Quite often there is a disconnect between pump and pool automation and we have to manually use the pump.
Questions:
1- If we need to replace this pool pump, do we go Jandy or Pentair? Will a 1.5HP do just fine or should we get another 3HP for our pool size?
2- Any ideas how to do a factory reset on this Pentair Intelliflo 3hp VS pool pump so it can reconnect to the Jandy iaqualink automation?
Thanks and looking forward to your replies.
It's always best to stick with the same maker when automation is involved. Jandy's support for other makers is very weak. Why set yourself up for problems?
Welcome to TFP.
Model numbers please.
What model number Pentair pump?
What model salt system.
Please create your signature with details of your pool and equipment so we can give you the best answers.
How does that disconnect show on the Aqualink and the pump control panel?
Questions:
Jandy unless you intend to dump your Aqualink, like I did, and move to the Pentair ecosystem.
With a spa a 3HP pump will give you better spa jet flow and be quieter.
Model number?
Nothing a reset would do will effect RS-485 control of the pump by the Aqualink.
