I just got a Pentair 5G Intellibrite LED light installed. I have it connected to an X-10 switch. When I turned the power at the breaker it just started flashing without me pushing on the x-10 button just like a disco ball or a medium speed strobe light. It started flashing not just circling colors. So I pushed the X-10 button and it stayed on blue, I pressed again and it started going through three colors in succession, pressed the x-10 off and on again to see if it would continue to cycle to the shows but it just turns off, I turned it on again and it goes back to blue and the cycle starts all over again. Per the manual. when its first turned on, its supposed to be white and then I could turn off and on the light switch a number of times depending on the color or show desired. I am also aware that it says it will stay off for a few seconds and then go the color selected but I am concerned about the flashing and also the fact that turning the light off and on with the x-10 switch button doesn't cycle through all 12+ settings. Are X-10 switches not compatible with these, could it be a problem with the wiring or do I just need their 100+ controller
