Hi,
I just replaced an older single speed pump with a 3HP variable speed Pentair Inteliflo. I bought a FlowVis & had it on my pool prior to pump swap. I bought a Pentair Multiport, Pentair FNS Plus DE Filter
It was:
60GPM normal operation Filter @ 8
40GPM Spa operation Filter @ 15
The inteliflo has a few default RPM speeds.
Speed 1: 750 RPM (80 watts) = 0 GPM Filter @ 0PSI - No Skimmer movement
Speed 2: 1500 RPM (267 watts) = 30 GPM Filter @ 0 PSI- Fast Skimmer movement
Speed 3: 2350 RPM (912 watts) = 60 GPM Filter @ 6PSI - "Regular" skimmer movement (similar to old pump)
Speed 4: 2950 RPM (1730 watts) = 90 GPM Filter @ 12PSI - Slower skimmer movement (surprising).
I am trying to figure the proper speeds for various devices. Previously I would run the pump 12 hours per day. I dont know if that is needed now or how to do the math on what the proper flow would be.
First off - is 90GPM to much or needed (unsafe?).
Any other advice would be great as i need:
Spa RPM
Cleaner RPM (uses a booster pump)
Heater RPM
regular RPM (normal non heating mode).
Rich
It was:
Spa RPM
Heater RPM
Rich
