Pentair control panel aux
Oct 3, 2010
68
Cypress, TX
Hi all,
I have a Pentair control panel and just installed a Stenner liquid chlorine pump. I temporarily have an outdoor timer plugged in but it only has 1 hour increments, so I need to hurry and get it wired into my Pentair panel so I can adjust the start and stop time.
I know I need to add an outlet and wire it into my panel, has anyone done this before - is it something I should hire an electrician to do or is it pretty easy for the average joe?
TIA
Russ,
If you can wire a wall outlet, you can add one to your ET...
The main thing to keep in mind is that you can only have 12 total schedules, including any egg-timers... So, for example, you wanted to run the acid pump 6 times a day you would need 6 available schedules...
How many schedules do you have now? How many egg timers that are not set for the default 12 hours?
Also, is your Pump/Filter relay being used now? What voltage is your Stenner?
