Yes, it's 50 GPD. The IntelliChem is set to do a "5 oz dose" which I'm assuming is dependent on the value you put in for GPD. Since mine is set to 50, and the pump may be doing far less than 5 oz and is likely part of my problem. As an observation, the pump runs for a very short period of time when it's dosing (like seconds or maybe a minute, not hours)....so I'm assuming it's doing the math on how to measure "5 oz" based on my 50 GPD value for the pump.
It's been dosing for about 24 hrs at 2 hour intervals, and PH hasn't moved - it's literally at the exact same spot as yesterday. Pool has been covered for the last 17 hours.
So I'm thinking either it's not actually pumping fluid, or the dosing is too low. I don't have a great way to test if it's pumping fluid, since I don't really want to watch it pump acid into something...and given what you found, it leads me to believe that the dosing is too low...
When lowering PH, what's an acceptable dosing strategy? I diluted my MA 2:1 with water. My PH is at 7.71, and I want to get to 7.6. Pool math says I need 7.5 oz of 31.45% MA. Since I'm diluted 2:1, I need 22.5 oz in total. How fast should I be adding? (what's an appropriate dose size?)
