I have a Pentair Intellichem system with an acid pump for Ph control. The high level issue is that acid isn’t being delivered to the pool when I dose it. Everything seems to work right up to the check valve where the acid feeds into the return line. When I manually dose it, the pump works. I’ve removed the acid feed line from where it goes into the check valve and acid comes out when I dose it. When I put the feed line back into the check valve, the pump pumps but no acid comes out of the pool end of the check valve. I replaced the check valve with a new one and I get the same behavior. I know it’s possible I got a bad valve but it seems unlikely. Does anyone have any ideas what I can do to troubleshoot it? Thanks!
