PB in Austin that will do SWG?
Jul 2, 2014
82
Austin, TX
I am dead set on using SWG and my husband's business is stone so we aren't worried about that at all -- he can seal it all day every day and has access to all the good stuff. I know there's more to it than that, according to some of the pool companies we've talked to anyway -- metal corrosion or equipment corrosion because of the electrical charge?? I don't know but I really want to do salt and we've talked to a few that just are dead set against it and won't warranty anything with that system.
Has anyone used a builder in Austin or surrounding area that will install a salt system AND won't try to talk us out of it/sell us on UV/ozone, and will give us the same warranty?
I would love some recommendations!! Thank you!
Reply or PM if you can :)
My understanding is that Cody Pools would have done it for us, just would not warranty the stone coping. So if your husband is fine with the stone piece then that shouldn't be a problem. Now the part about not trying to sell you on UV/Ozone, no promises there... All PB's try to push or sell their own methods or ideas so you are going to get some sales push on something...
I guess I am lucky, as my PB in Houston was adamant that we only do SWG and to avoid chlorine. Based on many of the comments I've read on here for Texas and Houston for that matter it appears my PB is the exception to the rule.
We are also doing travertine instead of flagstone to help reduce any corrosion issues. Additionally, my equipment pad is located on the opposite side of my house very far away from my pool.
