Hello, folks.
Apologies if this has been covered. I poked around for about an hour and kept getting lost on tangentially related topics but didn't find anything that answered my question. Which is: can I use pavers to increase the height of a significant area under the pool?
This is what I'm working with:
The blue area from 12-3 is about 8-10 inches or so on average lower than the average of the rest of the surface. I have TONS of pavers lying about. Can I level that low area, herbicide it, place the pavers just in that section, and then level the rest to the height of the pavers?
I'd then herbicide the rest, and then either go with a sand or foam foundation for the entire area. I'm leaning towards foam.
I'm guessing this approach, if valid, would reduce the amount of soil I need to remove by 60-80%.
EDIT: I'd also be using pavers under all the legs... level with the surface, and cutting the foam (if I go that route) away from those leg support pavers.
