In various quotes for paver deck around gunite pool, some vendors use crushed stone base and some use crushed concrete base. Any problem with the crushed concrete? I want to make sure it drains well to resist any freeze/thaw issues in the winter.
I am not sure if you can see well in these pics, but I used NDS Mini-channel drain. Kinda pricey, but it allows you to take off the grates to clean out drain if necessary. I have all areas sloping to drains or otherwise away from pool. My advice would be spend 80% of time on base prep and 20% on actual paver install and use a laser transit.
What kind of pavers are these?
