partial drain vinyl liner-temperature question
pookiesunshine
0
717
Cincinnati, OH
I will be doing a partial drain/refill on my vinyl-lined pool. i am aware of the need to leave at least 12 inches in the shallow end. I saw something in a recent post that peaked my curiosity on temperature requirements. Can i do this while water temp is around 60 or should i wait for higher? I could not find anything on this by searching. Any advice? Thanks.
ok, after original post, i found where i had seen a mention of temp; also just found this response to the post just prior to it about 80 degrees:
You're right about the temp for the liner. .......]
is 80 really necessary? i did not want to wait that long.
