I have water coming out from the underside of my 5' concrete deck that surrounds one side of the pool. It is in a direct line with my Paramount paralevel automatic water leveler. I shut off the valve to the water leveler and the water flow stopped. I tried to take the float out of the cannister to see if there's any cracks or other signs of a leak, but I can't get that float out. I pushed down and tried to give it a counterclockwise 1/4 turn, but that float assembly is stuck. There's not much room in the cannister to get a good grip on it and I feel like if I use channelock's on it for a good grip I'll probably just bust off the riser or something. Any tips would be greatly appreciated.
