I took pics with iPad and tried to attach but the forum said I exceeded my size limit. .?
Can you take a picture of the check valves? Certain check valves have a lot of head loss and would explain the excess pressure.
It is hard to tell from the picture so do you know if that is the flapper type of check valve or spring loaded type of check valve. Does the filter check valve look the same?
How about now?At this point, I don't suspect the valve because that is inline with solar on or off and since you have much lower pressure with solar off, that is not causing the issue.
And no, I don't see a link.
