Oxidizing Shock Water Testing
Jul 15, 2016
56
Florida
I typically only use liquid chlorine and float one puck to handle any days I miss adding but recently I ran out of chlorine and Added a bag of chlorine free shock someone gave me to the pool after a heavy load of ppl swam. Even after three days my FC numbers are high and it is showing some CC. Are my readings true or is the chlorine free shock messing with them like i read it does? If it is messing with, them will this go away with time?
Test - FAS DPD
FC - 11ppm
CC - 0.5
PH- 7.5
TA - 65 (low)
CYA - 50
The MPS shock will mess with all the chlorine tests.
It'll take a few days to disappear so you can get an accurate reading. I'd target a few FC higher than normal to allow for that and ignore the CC reading for a week or so.
In the future, don't add anything to the water unless you're sure of what it is and what it will do.
