- Nov 11, 2020
- 4
- Plaster
- Intex Krystal Clear
Hi Forum,
I have a question on a small pool I am building in my garden in the UK. It is more paddling pool sized. 5m x 3m x 1.2m internal. It will be constant depth and heated.
I have dug the hole - 6m x 4m x 1.6m by hand. Which took 3 months, as most of it was rock. And I am planning on insulating it with 50mm XPS insulation. I have received a lot of conflicting advice. Can the insulation go under the entire slab, or should it go on top of the slab?
The Slab is 6 inches (150mm) thick with a393 steel mesh in it. The walls are 12 courses of blocks laid on their side.
I have shown a picture of the excavation, a close up of the slab and insulation, and a picture of the pool in its entirety.
Thanks In Advance, Rich
