I'm curious as to what people have done to conceal wiring with outdoor TV setups. Since I have seamless steel siding, and the TV will go on a wall that's over 20' tall, my options with regard to cutting into the wall or using an overhanging soffit are limited - I'm either going to have to come through the wall at the exact location where I mount my surface-mount boxes, or come up from the bottom... From what I can tell, I'm limited to low-profile flush-mount boxes for both power and my signal (I'll use CAT6 to HDMI baluns), and I'll probably have to put these either above / below the TV vs behind it.
Has anyone uncovered a good way to keep these semi-concealed, or are I just stuck looking at the exposed surface-mount jboxes for power and LV cabling, either above or below the TV mount position?
