Disclaimer: I do not use ORP to control anything. It's strictly for my information.
So, I bought this Wi-Fi Ph/ORP tester from aliexpress mostly because I'm interested in anything related to home automation. And later replaced probes with atlas scientific (consumer) ones. It seems to show Ph pretty accurately. But ORP mostly stays in 450-500 range. Rarely going as high as 600. While I'm reading that in commercial pools 650 is a minimum.
It's SWG pool with higher CYA (60), which I understand would affect it. Just curious how. Everything mostly fine with my water, both, chemically and visually. FC is in 2-3 range, CC is .2-.4 range. Not sure if the latter is bad? Ph is pretty stable in 7.6-7.8 range.
