High maintenance pool due to trees on a wooded lot, pests, etc. Our pool is difficult to keep a FC reading, even when there has been proper CYA. Due to the debri, we have a high chlorine demand. Have been going to pool stores but want to try this alternative. We have been jsing a smaller test kit and it does measure FC or CYA. So i have used ours for PH and TA and then run to the pool store for the other 2 readings. We are ordering the TF100 tonight though!
Ive read about chemicals here, how they work and i found the calculator. I saw the post describing the chemicals and how to add them. However i was wanting to know what order to add them and how long to wait in between them. I need to put together a summary and print it out so that i can remember. I have my latest readings which are all low. Our pool pump died and we had to wait approx 2 weeks for the new pump and install and we have then shocked, vaccumed, and pool is clear. I can post readings below, but lets assume i needed to add everything, which i do . Can anyone please help me make this cheat sheet? If there is already one similar i didnt see, can you share the link with me?
Thanks!!!!
FC=0
TAC=0
CH=270
CYA=0
TA=30
PH=7.0
Thanks!!!!
FC=0
TAC=0
CH=270
CYA=0
TA=30
PH=7.0
