Just opened the pool, and it's very green. There is algae that is growing up from the bottom, some a couple feet long. Yuck. I should also mention, last year was my first time closing the pool.
Opening went okay, got everything hooked up, the returns bubbled out air and anti-freeze came out - good sign! I cleaned the sand filter with the hose method. Put lube on the pump gasket, took out the gizmo. Mechanically, the opening went okay.... except there is bubbles coming from the returns. Bummer.
Here's my numbers...
CYA: 20 or less, test kit only goes up to 30, but going over the last line almost got it there.
PH: 7.1
TA: 60-70
CH: 130
Pictures and Video
Green pool, air in pump, bubbles in returns.
Shared album - Tom Kurtz - Google Photos
I added about 1.5 pounds of stabilizer and borax, and about 1.5 jugs of bleach. If I did my math right, this should bring it a couple PPM above shock level - added it all after the sun went down.
Questions
Did I do something to cause this?
How worried do I need to be about the bubbles?
How do I diagnose the air leak? (see pictures/video in link)
Any advice advice for my levels, or just follow the normal SLAM procedure from TFP post?
My pressure gauge is stuck at 35, and goes up to 50. That means 15 PSI right, or should I be worried about that?
THANKS GUYS/GALS!
PH: 7.1
TA: 60-70
CH: 130
Pictures and Video
Questions
THANKS GUYS/GALS!
