Hello. We didn't open our pool last year b/c it really needs new plaster. We planned to have that done but couldn't find anyone to do it. (I've been trying to find someone for 4 years -- small town, two hours from any cities.) Anyway, we are opening a swamp. (And I may have found someone who will plaster later in the summer.) I have successfully used TFP and have successfully gone from green to sparkly in the past, but I'm having trouble deciding the best way to proceed this time.
I have always had trouble keeping the CYA up - I know most people seem to have the opposite problem, but I am constantly trying to bring it up. Same with Calcium Hardness. And, I'm constantly having to add muriatic acid to correct the pH. (Our pool has issues.)
I currently have
No clorine
0 CYA
75 CH
and pH is un-measurable -- hot pink
Now, to my question. Do I just get started on the chemicals even though there is still a lot of gunk in the pool? Or, wait until we get all the gunk out? I've been brushing the sides and as much of the bottom that I can reach. I am frequently rinsing out the simmer basket/sock and back-washing the filter when the pressure starts going up. I am reluctant to put in 50 lbs of Calcium, which it needs, and adding lots of stabilizer, which it needs, when we will be replacing water through back-washing the filter and/or vacuuming. Should I add all the chemicals even though we will lose a lot, or just add the bleach at the beginning? (And, is it possible to do this without vacuuming, or is that an imperative part of this process? Once we began using TFP method, we never needed to vacuum again, until now.)
Thanks for your help!
I currently have
No clorine
0 CYA
75 CH
