Hi Everyone,
Great to be back on TFP for another season!
Not sure if this belongs in Testing and Balancing Water or where I put it in Algae- prevention and Treatment- I'd argue both
. We took the cover off the pool last night to a big surprise. This is our 16th year with our pool and while every start to the season we take the cover off to a dirty pool, the water is usually not too bad. You can see the bottom fine and can tell there are 1000 worms, but generally the water is fairly clear and you can at least tell we have a light blue liner. Not the case this year! We were shocked to see it deep green. Our "pool guy" who we have used since the beginning to open and close our pool each year thought maybe a more mild winter was the cause, but that has happened occasionally in years past and this hasn't happened...anyway...the pool was green for the first time. After just a few hours (after getting us up and running) the pool water started showing signs of improvement. Before and After pictures are attached. The "before" was the deep green today at 2:00 when he got here and the "after" about 2.5 hours after he left.
To get my baseline after he left, I tested the water around 5:00PM and I was very surprised at how low the FC was given he just added a ton of liquid chlorine (I have a message in to him to try and find out just how much he added and clearly he did add it for the relatively quick results, but why would FC drop so fast? Test Results are here:
FC: 1
CC: .5
PH: 7.3 (always a little low for me at startup)
TA: 60 (always low at startup)
CYA: 0 (I expected it to be low with all the rain/snow all winter)
What stands out to me is FC only 1. Is it possible algae would eat through the chlorine he added that fast? I know there is no stabilizer in the water, but I would think FC would be much higher than 1 unless that;s just too much algae to "stay around". I was also stunned to see CC at only .5. I almost recorded it as zero because it didn't turn a slight shade of pink for a a few seconds after 5 drops. It very well could have been 0. Prior to testing, I was preparing to go through the SLAM process (something I really haven't done before). These results make me think I just need to brush/vac and backwash and add more bleach and stay after that cycle until the water is clear and NOT SLAM? Agree?
Also, how much stabilizer should I add at this stage? I know it is typically suggested to be around 60-70 for a salt water pool, but what about to begin the season here in my situation with my current test results? I have added no chemicals so far and will test tomorrow morning. My guess is the FC will be zero and maybe the CC will be up?? If that happens I will post back because that might require a different course of direction? Advice with my current situation?
Thank you!
FC: 1
CC: .5
Thank you!
