Hi all,
Can i care crytal water just put only a little products without SLAM?
Dawnback: SLAM method creates a dificulty because we need to wait until FC below 5ppm. Sometimes one day all !!!!
To avoid buying more products (algaecide or alum pac) i do it for heavy user pools this script:
1. Use Chrorine to maintain level FC 4ppm and monitoring twice a day. (Puts half-a-day and at night);
2. Verify the water level of pool and Cyanurate acid;
3. Verify ph interval with eye in TA;
3. TA should vary with function of aeration of you pool: I think 60 ppm can celing ph to 7.6 with so munch gas-off(co2) in pool (similar to hot tubs);
4. Oxidizer with MPS twice a week. If the more bathers the more MPS.
The golden rule: sanitizer + oxidizer + protected ph (TA compatible with pool) + monitoring daily with reagents.
Products used: dichloroisocyanuric acid, bake soda and MPS. Rarely i ve used ph regulators.
Hose water is always treated and know your parameters (ta, hardness, ph).
What do you think about script above for heavy use pool with little time to apply alum or wait fo recover from SLAM method daily?
bye.
bye.
