- Dec 17, 2017
- 667
- Fiberglass
- Astral Viron eQuilibrium EQ45
MY VS pump that I use is supplied with a nylon flapper style one-way/check valve which is designed to fit directly into the outlet.
The valve itself is not water tight as it is made from nylon, therefore it does has not have true 100% water sealing capability.
Just curious as to why the pump is supplied with one? Instructions don't really say anything about it.
It reduces the outlet diameter a tad and it does add some restriction to flow due to the reduction in diameter of the outlet when fitted. I have removed it in my case and I can actually see/measure a slight increase in flow in my system - so it does impact performance.
Initially I thought it does the same job as a typical check valve which may be fitted on the outlet in some circumstances but not exactly sure?
Pump without valve - You can clearly see the difference in the outlet diameters....
