I've been talking to PBs about doing our replaster (probably quartz) using the guidelines published by onBalance for the plaster mix and 4-6 hour delay for the fill, and getting pushback about the mix and the delay, and being told they follow NPC guidelines. I visited the NPC website this morning and read their bulletins but can't access the manual. So what are the NPC guidelines about the plaster mix? Are the onBalance guidelines much different?
About the fill timing, Technical Bulletin 2 - Hydration and Curing says "Interior cementitious finishes begin to hydrate during the mixing process with water. The new finish is cured by filling the pool with water after the surface has hardened to a point that it can be immersed". The recommended delay must be about waiting for the finish to harden, but does the manual say anything else that would support delaying the fill?
Thanks. I've found one PB that said he'd read the onBalance material and that's a good start, but knowing the NPC side of this might help our discussions.
