- May 23, 2015
- 25,733
- Plaster
- Pentair Intellichlor IC-60
Just a thought bubble from me as I was thinking about this the other day. I wondered if the Stenner Pump owners here on TFP would be interested in an on-site chlorine generation technology such as this -
On-Site Generation, Sodium Hypochlorite Water Treatment | Products | MIOX
The above is just for illustration purposes although the company does offer their Rio-Zuni model which is capable of producing up to 2lbs of chlorine per day. There are other direct bleach production systems out there too, such as Chlorine Genie.
The only inputs, aside form electricity, are salt and a source of low CH water. My municipal water out of the tap would not be usable for a process like this so anyone with high CH water would likely need the additional step of a small, salt-based water softener to create the input water or a small-scale RO system. The above unit generates a mixed oxidizer chemistry (chlorine & peroxide) so it's not exactly a pure chlorine generator. One benefit of the mixed oxidizer process is that it eliminates (or reduces) the production of dangerous hydrogen gas at the expense of more pure chlorine production. I see no downside to the introduction of peroxide into the water as it will simply dissipate very quickly. The unit appears to have an ethernet port on the back which means integration with a remote controlled automation system is entirely possible.
It would be interesting to see a system like this in action. Honestly, if the price point were right, I'd consider direct chlorine (or "mixed oxidizer" injection) over an SWG system. One reason why a Stenner pump is not really an attractive option to me is that I don't want to lug bleach around and my outdoor temperatures are so high that bleach degradation would be an issue unless I moved the delivery system indoors or under cover. A direct generation and injection system eliminates those problems.
Again, just a thought bubble....
