OmniPL doing odd things (again)
milguy11
Active member
Feb 18, 2017
31
Rockledge, FL
we used the spa a couple days ago - no problems.
today, the OmniLogic App will not stay in "SPA" mode. Keeps reverting to Pool - IN THE APP.
But, the Spa valves have turned and the gas heater is working - even though the app is reporting the system in POOL mode.
I cycled power to the OmniLogic (reboot) and closed/re-opened the app several times.... no change. same behavior.
if i change to SPA mode in the app, about 30sec later it shifts back to pool mode.
App is latest, 5.1.40.
SMH.
I suggest you report the problem to Hayward Support. Sounds like an app bug.
My app is stuck showing the pool equipment at one specific setting, but these settings do not match the actual hub settings and equipment.
I’ve reset my network, Hayward app, OmniLogic (reset breaker), and I can’t get it going as well. Started last night.
After messing around with mine i finally checked here, glad to know it's not just me. Been stuck since mid afternoon yesterday. Schedules still run and control from the panel works fine, guess I'll live :)
Web/App control is working again. Woke up at 3am to water features on and my spa and heater running, guess Hayward decided it was a good idea to reset the equipment state back to whatever it was at when it went down Saturday afternoon.
