OmniLogic not sensing Flow
meow_meow
68
Las Vegas, NV
Bumping this thread. Pump turned on and primed this morning - then runs for less than 30 seconds and shuts down.
OmniLogic. Phone shows alert “FlowSensor: No water flow FlowSensor”
We have a salt system, BUT it is running on just chlorine. We have it running like this for months now. Nothing has changed other than it was rather windy here yesterday. I clean the pump baskets.
Moved from here.
More than likely you have a bad flow sensor. They are easily replaced.
In the meantime, you can turn off the flow detection so it doesn't shut down the pump in the configuration menu.
Reactions: meow_meow
Ok. I think I found a thread with a YouTube video posted for OmniLogic. That being said, if you have any other info on where to find it specifically, I’d appreciate it. I didn’t see anything in the physical manual that I have for the system, unless I missed it.
