Omnilogic HLRELAYBANK pinout?
ssanto
13
Leander, TX
Hi,
I need to add one more relay to my system so that I can control an additional area of landscape lights independent from the ones around the pool. All four of my relays that come with the Omnilogic are already used.
I found HLRELAYBANK for like $600. Wow! I got the PN for one of the relay's on my board and it's only $25 to buy one of those. All I need to do is wire it into the right pins on the Omnilogic mainboard.
I found a Hayward Oncommand 4 relay bank and it's wires are exposed so you can see how the pins on the board map up to the relays. But the Omnilogic uses a different connector and the HLRELAYBANK doesn't show what wires are going to what.
Any ideas?
Sal
Ah-hah! I found that instead of the HLRELAYBANK which gives me 4 relays, there are also the single ports on the mainboard for HLRELAY-9 and HLRELAY-10 which each connect to a single relay. And for those I can see in the pictures for those HLRELAY parts how the wires from the relay match up to the printouts.
On the other hand... It looks like I can find the genuine hayward HLRELAY already wired up for $85 so it'll probably be worth it to just buy it already wired.
FYI.
If you are using Hayward transformers and colorlogic lights, the transformers have to be wired to one of the original 4 relays to work properly.
