Omni PL SWG not turning off when pump off
BC78
74
NC
Fiberglass
Hayward Turbo Cell (T-CELL-5)
Ok so odd issue here. Earlier I had a "No water flow" notification on my phone the pump had shut down. My heater shut down but the SWG didn't. I looked in the config to see if there was a setting to turn the SWG off when there's a no water flow situation and there's no setting i can find for the SWG that activates that. The heater setting have it but not the SWG. Am I missing something here?
Why did your pump shut off?
What state did your Omni PL think your pump was - running or off?
How do you know your SWG was not off?
Your cell has a flow switch which turns off the cell when you have no flow.
Filter sock clogged
App and control panel said pump was off and it also sent me an email saying it was off
App said SWG was still on and so did control panel
The system has just the single flow switch for the heater and cell
I tested it a few times after yesterdays update and it seems to be shutting down fine now. Might have just needed a hard reset from the update or the update fixed it
