I opened the pool today. I first ran the Jacuzzi Spa in a closed loop. Valves set for drawing water only from the Spa....Returning water only to the Spa.
The pump primed nicely, pressure gauge came up to the right number. The filter was first set to recirculate. The heater came on perfectly and a spark lit the burner...all good....SO FAR
After about 10 - 20 seconds, a very large flow of water began spewing from the Spa Air Intake...I have always assumed this is used to mix air with the water returning into the Spa. And it's a lot of water coming out.
It'll drain he spa in 5 minutes.
So it seems to me: Air in is good, water out bad! What's up with that ?????
I noticed that if the return valve position to make the water go to the spa was switched over to the return to the pool, the water stopped flowing out the Air Intake.....so something it seems if wrong on the RETURN side.
The photo shows the air intake pipe coming up out of the ground, with the water coming out.....when the return valve is set for the Spa. When set to return to the pool, the water stops.
I have had three pools with the Air Intake and Spa...it gurgles when operating normally, i.e. bringing the air IN when the spa is running.......does anyone know what is happening here? This is a new one for me.
Confused. Thanks
Confused. Thanks
