- Jun 8, 2019
- 4,574
- Vinyl
- Pentair Intellichlor IC-60
Do you have a pool vacuum? If not, you should get one of those as well. Best to have something to back up the robot and you could use it now.
The SLAM requires you to be brushing the walls and vacuuming the floor (or cleaning with a robot I suppose), but you should get chlorine into the pool ASAP to make sure it doesn't go greener.
I would recommend adjusting your pH to 7.2 and then getting the FC up to 16ppm. If you can source a vacuum and hose and a brush/pole today it would be a good idea.
