Hello All, I'm a long time lurker, I've learned quite a bit from this forum. I know the people here are down on tab chlorinators, but I'm thinking of installing one on my small pool (9000 gallons). Previously I've used puck floaters and occasionally get a stretch of many months where they work before I have to switch to liquid chlorine, or do a quick half drain and refill (takes 5 hours). The puck floaters need to be refilled every week, and I'm hoping with the chlorinator to be able to go on trips for 3/4 weeks without having a friend do anything to the pool. I've recently got an autofill and it's been great!
The pipe out of my cartridge filter elbows up immediately and has a 3 foot vertical section. On this there is a check valve. Then it elbows horizontal to a bypass/solar switch. Solar is not working so it's always on bypass. solar/bypass returns come together and elbow straight down to the returns.
I'm thinking of putting the chlorinator inlet right after the check valve and the outlet near where the returns go into the ground. I realize this does not give much pressure differential. The inlet will be a couple feet above the outlet, but there will only be a few feet of pipe in between the two. Will this work ok with an offline Pentair 300?
I know you're supposed to plumb the inlet before the filter for more pressure, but I've also heard this will clog your chlorinator.
I considered plumbing in the Pentair 320 inline, but that would require me to elbow the vertical return line to horizontal, then elbow it back to the returns. Seems too convoluted. I also note that this inlet and outlet in the 320 appear to be inches apart. There seems to be a pitot tube elbow for the inlet, just above that is the check valve for the outlet. The 320 does get gravity working on it's side to drop solution through the check valve, but I can't believe there is much pressure differential. Is there something I'm missing in my analysis? Is there some other magic that the 320 is doing? Why does the 300 need more pressure differential when the 320 appears to have almost nothing? The 320 appears to be the most recommended chlorinator on this forum. If the 320 works, I imagine the inlet/outlet locations I've selected will work.
I know there are people on here that are gripping that they only get 1-2ppm from chlorinators no matter what they do, but on my small pool that may be enough.
