After completing 3 days of a SLAM, I'm not seeing much progress. When we opened up the pool 6 days ago, the water was extremely green, but the green went away after running the pump for several days before starting the SLAM, even though I didn't add much chlorine during that time. When I finally started the SLAM, the water was blue but extremely cloudy. I could see the first step, could barely see the second step, and couldn't see the returns. The water looks pretty much the same as it did 3 days ago, but the second step is a tad bit easier to see and I can barely make out where the returns are now. I have been brushing twice daily and backwashing when filter pressure goes up 25% (I've only needed to backwash once in 3 days. Sand is only 2 years old). I haven't vacuumed yet because I'm worried that there could be some debris down there that we cannot see. We don't have a robot that we can throw into the pool. (Our pool is surrounded by trees so we normally get leaves in our pool over the winter, even though it is covered.) We have blindly netted the pool several times though so I don't think there is much debris down there. I've been using 10% liquid chlorine with a April 10th date and have been adding enough chlorine to get it up to 12 ppms using the pool math calculator. I've been testing/adding chlorine every 3 hours during the day and add the last dose when the sun goes down at about 8 PM.
When I woke up this morning at 7 AM, I tested the water and here were the results:
FC: 9
CC .5
PH 7.6-7.8
TA 50
CYA 30-35 (can barely make out dot at 35, dot disappears completely at 30).
Based on there results and what I've been doing during the SLAM, does anyone have any suggestions for me on what else I could do to get this pool to clear up? Is it possible that CYA is 35 since I can barely make out the dot at 35 so I need to be increasing the FC to 14 instead of 12? Should I decrease the PH or increase the TA or is it possible that the PH/TA is inaccurate since FC was 9 when it was tested? Would it help clear the algae faster if I increased the speed of my variable speed pump that is currently set at 2300 RPMs? Should I be backwashing daily, even if filter pressure hasn't gone up by 25%? Our pool is fiberglass so I normally see a lot of progress after the first 3 days and I've never had a SLAM that lasted more than 5-6 days. I'm not going to be around next weekend to add chlorine to the pool so I need to get this pool cleared up before then.
FC: 9
CC .5
PH 7.6-7.8
TA 50
